Are you saying the supplied software does not install in Windows 8? Being as the camera uses SD memory card, SDHC memory card, SDXC memory card, then Windows 8 will be able to read those cards. As for which cameras are compatible with Windows 8, they all should be.
Calendar Creator is not supported for Windows 8 at this time. Even the newest version which is 12 is not supported fo Windows 8. You could try running it in compatability mode however.
Right click the Icon and select "troubleshoot compatability"
It looks that you would like to install drivers for Linksys WPSM54G. Please write to us with the answer of the following question. 1) Do you have the driver installation disk with you? 2) Did you try to install the driver? 3) Did you get any error while installing it?
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
Chances are that you optical drive is not compatible with windows 8 so it does not work . But you can get a separate optical disc drive which is compatible with windows 8 and work it out.
google setting compatability modes windows 8... the game needs to run as emulation of the platform it was written for see http://www.online-tech-tips.com/windows-8/run-a-program-in-compatibility-mode-in-windows-8/
