How do you insert a drill bit?
Don't think there is much to it. See page 4 in this manual
http://www.ryobi.com.au/Ryobi/files/e0/e029b72d-32ec-4e92-a555-2a3caac4fa92.pdf
Pull the chuck out to unlock it and push the drill bit and chut back in to lock it.
Hope this helps.
Testimonial: "The problem is that the drill comes with one phillips screwdriver bit that has a hexa base. The drill bit kit I purchased... the bits have round bases and they won't stay in."
You may need to purchase hex shaft drill bits similar to those recommended by Ryobi -http://www.bunnings.com.au/ryobi-hss-dri...
That works for a hexa based bit, however, if you look closely, you will see the large spade bits have the hexa bottom, however, the other bits have a round bottom...
I purchased a Ryobi drilling and driving accessory kit. The spade bits and the insert bits have the hexa bottom. The rest of the bits have round bottoms.
i was not careful when i responded earlier. I did not realise you have an impact driver and not an impact drill. You will not use impact driver to drill holes but to fasten and unfaster hardware like screws, bolts etc. So it is usually tools bits with hex shank. That is the reason you could not attach the round shank drill bits. Sorry for the confusion. Read this article -http://www.thewoodwhisperer.com/articles...
