Question about Onkyo TX-SR606 Receiver
No sound with the tx-sr606
I have an onkyo tx-sr606 and it is hooked up correctly and was working yesterday, now i get no sound at all out of any speaker on any input, only video. light on subwoofer stays red and when i hook up the auto-cal mic and hit enter nothing happens. everthing hooked up to it is through hdmi.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
This is a problem of DSP. If enter service mode,
You will see a picture like this. You can do nothing
Except selling this amp cheaply. This DSP ??????
Causes NO SOUND in all channels. Besides, never
Buy 2nd hand onkyo from 5/6/7/805 to 5/6/7/848Series amps. You will suffer the consequences!!!!
no sound with the tx-sr606 - dsp problem-cul4vjmzkuvncverhuthjcbk-4-0.jpgdsp1-uogyjvcdpkwkvogd1g1ztygl-3-3.jpg
Posted on Feb 13, 2018
  • Ambrosia Heart
    Ambrosia Heart Mar 06, 2018
    If DSP is in good condition, relays of the seven channels will ALL be "ON" and the relays indicators will ALL be lit up when all channels stereo is selected.
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
Anonymous
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
Anonymous
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
Dennis McCollum
  • 137 Answers
SOURCE: Onkyo TX-SR606 HDMI Input
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Posted on Apr 17, 2010
Dennis McCollum
  • 137 Answers
SOURCE: Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Posted on Apr 19, 2010
I have an Onkyo TX-SR606 connected via hdmi to a Sony Bravia 52" lcd screen. My inputs are a Panasonic DMR-EX77 dvd Recorder and a PS3 via hdmi into the Onkyo. All worked well for a month but now it takes...
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Jul 02, 2010 | Onkyo TX-SR606 Receiver
Apr 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Aug 08, 2009 | Onkyo TX-SR606 Receiver
Remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Feb 20, 2009 | Onkyo TX-SR606 Receiver
No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Dec 16, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
1,271 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
