Ovens Logo
e
e sloneker Posted on Apr 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan appear to function normally, but the heating elements will not come on. I'd appreciate any suggestions or recommendations.
Ty Roshdy
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • GE Expert 650 Answers
  • Posted on May 10, 2014
Ty Roshdy
GE Expert
Level 2:
Prodigy:
Answers
650
Questions
Helped
137050
Points
915
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
5 Related Answers
VEKAT
Devabhakthuni Venkateswara Rao
  • 225 Answers
  • Posted on Dec 11, 2007
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 23, 2008
SOURCE: Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Anonymous
  • 95 Answers
  • Posted on Mar 02, 2009
SOURCE: heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Anonymous
  • 87 Answers
  • Posted on Mar 04, 2009
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Anonymous
  • 8 Answers
  • Posted on May 17, 2009
SOURCE: Convection works but Microwave does not heat
try using a voltage stabiliser .it may just solve ur problem..
1helpful
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
1helpful
Lower element on GE Profile electric convection oven went out
Although this is an easy repair, the element is not a real common one so many service / parts stores may not have the WB44K5018 in stock. Make sure to get on finding one fast to make T day go smoothly. Here in the midwest I use C.E. Sundberg for a lot of my parts, as they have a good stock and are fast. (they have this part on hand at their main branch in Chicago and at Omaha, Fargo, and St. Louis Park (MPLS). The repair is essentially: Turn off power. Remove two 1/4 inch hex head screws. Pull element forward a couple inches into oven cavity to access the electrical terminals. Remove push on wires from old element. Install new element. One of the easier repairs.
1helpful
Microwave stopped heating
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
