WHEN I START MY PC A RED LIGHT FLASHES 4 TIMES THEN IT SHUTS DOWN PC WHAT DO I DO?
Hi:
Here is what I would do...
Turn the PC off and unplug it. Then press the power button to drain any residual power from the motherboard.
1. Remove and reseat the memory module(s). Restart the PC.
2. If removing and reseating the memory module(s) doesn't work, if you have more than one memory module installed, remove all but one, and start the PC.
Test each memory module one at a time, until you find the one that is bad.
If none of that works, check for bulging and leaking capacitors on the motherboard. These may be particularly noticeable around the processor area.
SOURCE: red flashing lights, will not completely start up
Do you have a windows XP cd?
If so you can try booting from the cd and running recovery console.
from recovery console type chkdsk -r
This should repair any bad sectors on your drive, allowing the drive to boot
(this scan may take some time)
SOURCE: power problem with HP Compaq d530 Convertible Minitower Desktop
Try this first : Load the bios (F10 - vista or F1 - XP), Load setup defaults F5. then Save changes F10, and try restarting your pc.
Secondly, after restarting your pc, on the HP invent screen, keep tapping on F9 for the diagnostic test
If theres no any error message, press any other key ACCEPT for the 'R' key to restart or repeat the test.
Other sollution
Try loading into safe mode F8, select on the safe mode and let the computer stays into safe mode for sometime.
If the pc doesnt restart, it means theres no any HW problem in ur pc. If it does the same, it means, you will need to check your Power supply, M/board with your tech
SOURCE: hp compaq desktop stopped running,
4 beeps indicates ram or video issues.
Try reseating the ram modules and checking the video card (or try a video card if you are currently using the onboard video)
Sounds like it is over heating. Open the side panel of the PC and check to see is the fans are all running when you power it on. More specifically, the fan that is over the processor/heat sink is the most likely to cause the computer to over heat and shut down.
For HP EliteDesk 705 G1 Microtower
HP EliteDesk 705 G1 Small Form Factor
HP EliteDesk 705 G1 Desktop Mini
Activity:
Red Power LED flashes four
times, once every second,
followed by a two second pause.
Beeps stop after fifth iteration
but LEDs continue until problem
is solved.
Beeps: 4
Possible cause: Power failure (power supply
is overloaded).
Recommended action:
Open the hood and ensure the 4 or 6-wire
power supply cable is seated into the
connector on the system board.
2. Check if a device is causing the problem by
removing ALL attached devices (such as hard,
diskette, or optical drives, and expansion
cards). Power on the system. If the system
enters the POST, then power off and replace
one device at a time and repeat this procedure
