I want to change the password so that the people who used to have the password can't connect to it now with their devices.
SOURCE: Connecting to a macbook
Hi.
This is all what you just need to do. You need to get you mac address first and edit it using a computer that is currently connect to your router as you are using Mac filtering. To check your mac address :
To find the serial number located on the computer
If the MacBook is not turned on, you can open the computer's
battery bay to find the serial number.
The MacBook serial number and Ethernet ID (also called a MAC
address) are located on the bottom of the computer, underneath the
battery, in the battery bay.
SOURCE: airlink router 101 can't connect 2 devices
this is a Dlink software bloqued, need to reset( push the reset buton more than 10 sec) the router, and config again. Caution change all router passw every 30 days or less.
SOURCE: changing password
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
SOURCE: My iPhone 4 will not connect to my wireless router
There are 3 things to try:
1: reset router
2: on iPhone, Settings, General, Reset, reset Network Settings.
(this erases all saved network settings, if you use other wifi, you will have to set them up again in the iPhone)
3: Change the password on the router, try to use a 13 character password if possible, as this seems to sometimes help.
If all that doesn't work, then you may have an issue with the phone itself.
