I have a sony HDR HC3 Camera.suddenly its display not working.how can i fix this problem ? i can't see anything on display
SOURCE: repair firewire Sony HDR-HC3
I have a HDR-HC3 and I had the same problem too... This model has ALOT of problems with transferring files and I need to pay $90 to get it repaired... Try it on a Mac, if iMovie cant pick it up it means you have a firewire problem.
SOURCE: External Microphone for Sony's HDR-HC3 camcoder
ECM-HZ1 Microphone is compatible as HDR-HC3 has Active Interface Shoe for this mic.
SOURCE: My sony hdr-hc3 camera LCD just suddenly stopped
every time you open and close lcd pannel of camera there is a wire belt frome main circuit to lcd it brakes it is not a major problem but you can not do it at home. if you can see picture in view finder, take it to authorised service centre.
SOURCE: HD Video Capture Problem
Which software package are you using? My brother was able to solve the HD capture problem by using Adobe After Effects.
SOURCE: Sony HDR-HC3 LCD touchscreen blacked-out.
I have the same problem, screen went red then about a month later went black. If I rotate the screen so its on the outside when flat against the camcorder side, it works OK so I'm living with that for now, but you can't use the corder in the normal way for recording viewing the screen. All other functions are OK.
I have the problem, but not the solution.
Rob
