The freezer seems to work fine; I used a brush under to clean it but the fridge still not get cold enough. It registers 50 on thermometer.
If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty. If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
I looked at the fridge last night and there is ice buildup on the back wall! Is this the evaporator problem?
Does this require a professional to repair?
The same things is happening to my frig - I took everything out and defrosted the freezer, all the ice that had accumulated against the back wall of the freezermelts, runs down I clean it out, and it works better for awhile. Now the ice has re-accumulated, the freezer is working but the frig part is not as cool. - What can I do that won't cost tons of money? Is this something I can repair myself?
