SOURCE: Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through
the motions of the printing process, kind of stands still with indicator lights
just blinking away. This could be as a result of either of these scenarios.
i.
Ink cartridge
has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink
is finished. You must replace cartridge one at a time). If lights stop blinking
it confirms that your cartridge has become incompatible or developed
incompatibility. Also if your printer is the type that can work with only one
cartridge, remove one after the other (closing back the lid/cover) to determine
which in the set (black or color) has become incompatible. At the instance the
incompatible one is removed and you close the lid, the blinking will stop (for
printers that can print with one ink cartridge only). Just replace the
incompatible one and start printing again. In most cases the issue is always
with one cartridge. But if both are affected, you have to replace both. Because
of this type of problem, always keep used cartridges somewhere safe; they come
in handy for this type of troubleshooting.
ii.
The Cartridge
electronic panel is dirty
The electronic panel on the cartridge that makes contact with the
cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the
cartridge with copper “dots”.
The
Solution is to try to clean this panel with a piece of folded tissue paper
soaked in a bit of methylated spirit. Also try to clean the area in the
cartridge carrier/holder that makes contact with the cartridge’s electronic
panel (Usually this is more difficult). If you cannot reach it with your
fingers, use a stick or something with tissue wrapped around it. Allow to dry
well and return the cartridges, close the cover. The blinking should stop if
the electronic panel is the issue. Once the blinking stops the printer will
print.
SOURCE: print without using two refills? epson d120
Are you sure there is space for 5 cartridges? You are using T0711-714 right?
Check this link, it might help:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-D120/Drivers-Support?target=article&extn=.html&articleId=1312#toc5
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX6050-all-one-printer/Drivers-Support?target=article&extn=.html&articleId=2085#toc3
Hope that will help solve your problem!
