Coby MP301 MP3 Player Logo
A
Anonymous Posted on Apr 26, 2014
How do I turn the repeat button off - Coby MP301 MP3 Player
Same music plays over and over,on the hour. If I push button it will play all the different music? Please help!
Locating the repeat button in the Apple Music app
The most obvious reason for the songs to be repeating in the Music app is if the repeat function has been turned on.When you open the Music app the repeat button isn't actually visible on the standard-sized iPhone.
How to have songs stop repeating
  1. Open Music.
  2. Play a song.
  3. Tap on the small bar near the bottom of the screen that displays the song title.
  4. Scroll down until you see a button that says "Repeat"
  5. Tap "Repeat" until it is no longer pink (it should be gray
Repeat Random button won't turn off/ cds won't record
some require the remote to finalize otherwise it wont do that mode..
I have a blaupunkt san francisco sqr28 stereo. how do i input the code to get it to work. i have the code just dont know how to enter it
Turn on the radio,
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ station < ] button to save. (or the 5 button)
1helpful
Have entered the code on the radio but dont know which button to press to get the code to activate
It is usually Button 5 ....or occasionally Button 6
===================================== Ford Code EntryInstructions Once the unit has been turned on the display will show 'CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept. The set should now operate.
Put code in to my ford radio which button do press to enter
usually the 5 Button (occasionally 6 Button)
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
84helpful
4answers
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
How do i unlock the samsung dvd-l200
1) Turn on your player
2) With no disk inside press repeat on your remote ( do not press repeat ab ) . Repeat is a separate button
3) Press up arrow
4) Press down arrow
5) Press right arrow
6) Press left arrow
7) by now you will see a number on the screen.
8) now press the up arrow button until you read the number " 9 " on the screen
9) press the " repeat ab " button
1helpful
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
1helpful
2answers
Ipod nano 2nd generation won't fast forward
Turn repeat off in the menu.
Setting iPod nano to Repeat Songs
You can set iPod nano to repeat a song over and over, or to repeat a sequence of
songs. iPod nano repeats songs within the list you choose to play.
To set iPod nano to repeat songs:
m Choose Settings from the iPod nano main menu.
â To repeat all songs in the list, set Repeat to All.
â To repeat one song over and over, set Repeat to One.
To turn repat off, go to Repeat off.
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
