SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button. The safe opened. The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe. Wrong! Do it my way should this problem happen to you.
SOURCE: new sentry csw3813 stuck open
do you have the manual i have the same problem but close and the manual is inside the safe is the original keycode but dont remember it
SOURCE: Can not lock door, works fine when open but will
There might be 3 problems:
1. The door is not aligned anymore.
2. There is something in the frame where the lock goes in.
3. There is internal malfunction.
If you are sure about 1 and 2, you need to take it for service/repair.
Cheers
TeaCii
If you own website, add
live support almost free
Real
security guard to watch your cctv for $1/day
SOURCE: I have a sentry SO500. I know the combination but
A locksmith would try to replace the batteries. Sometimes you will get the green light but the batteries still will not have enough power to retract the latch.
