Product is Navman Tourer 695 LM. Every time I connect it to the computer, the internet disconnects. The internet is wireless. I have a Belkin USB Network Adapter connected to the computer. Internet can be reconnected once I've removed the Navman. I never seen this problem with any other USB connected device before.
SOURCE: i cannot connect to internet with my wireless usb adapter
you need to get into your routers settings and make sure that DHCP is enabled to automatically assign ip addreses and also go to the properties of your wireless adapter and ensure obtain ip address automatically is checked. Turn off any WEP or WPA security until you have all the connections, make sure that the adapter is on the same wireless channel as your router and that all the pc's are on the same network workgroup eg WORKGROUP or MSHOME. It may be as simple as right clicking on your wireless adapter icon in control panel>network conections and select connect.
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem? This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet. something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection. If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01 or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
SOURCE: D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
SOURCE: problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
SOURCE: Wireless adapter disconnecting and reconnecting
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Are you using the VISTA adapter driver on the disconnecting computer?
1. Connect Navman
GPS to PC via mini-USB cable.
2. Go to
'Start'
3. Go to
'My Computer'
4. Open the
Navman Unit
5. Open the
'Navman' folder
6. Open the
'Database' folder
7. Delete the
following file only - 'dababase.db'
8. Close the folders
9. Disconnect the
mini-USB cable then restart the Navman GPS by sliding the switch to
'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
