If it is an Error 2, Drain the coffee maker and open up the bottom part.
You will see the burner with a metal clip.
There are Two components on the burner. You want one with the brown wire with a white cloth coating. Slide the coating down to expose the Thermistor. Take a small piece of alluminum foil and cover the thermistor. Slide white cover back over the newly covered thermistor and put you coffee maker back together and enjoy your coffe
