SOURCE: accer orbicam problem
There is a utility bar that you can install that lets you change the default application folder:
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
SOURCE: Acer 5101 AWLMI orbicam problem!
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
SOURCE: Acer Aspire 5101 Orbicam
is acer aspire 5910g has a xp version driver bec I went to the site of acer they are not giving any xp drivers for this laptop
SOURCE: acer aspire 5101 orbicam
If you have a grey rectangle where ur cam should be. Especially after a
fresh install plus all the drivers. although Then here's your solution
Go
into device manager and delete the USB controller. Then reboot. When it
says new hardware found let it automatically install it. Et
voila, working cam :)
Complements of TruthSeeker 69
SOURCE: Acer 5101 wireless issue
Hello
Remember, the default restore disc that comes with the laptop has all the drivers for your notebook. You installed xp now, and most probably the drivers for your wireless is not installed. My advive will be to download the drivers for xp for your wireless. Then it should work fine.
Best regard
