This is a pretty simple thermostat. To manually turn on the furness just flip down the lower trim cover (exposing the function keys). Look to the right end at "System" and select heat. Afterwards you will then depress the red arrow key (next to the digital display). Enter the heat in which you want the room to warm up to. This setting will be temporary and may change back to the programmed setting depending on how yours was setup. Any other questions please write back.
SOURCE: Sony Liv Clock Radio, Cd Player
I have a sony dream machine ICF-C18 and had day light saving time and cannot change the time
Please help
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: I need an instruction manual for my RCA Clock
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you can have. Press Cancel and then WKx. That will turn off the alarm. If you press WKx more than once, it will cycle through small symbols on the bottom of the screen with the number x in front of them. First symbol means it will have a sound alarm for alarm x, second symbol means it will have a radio alarm and the third symbol means it will play the CD to alarm. You set the time for alarm with the slide switch at the back of the unit, selecting WK1 for alarm 1 and WK2 for alarm 2. You can have both alarms active at once, or either one singly.
SOURCE: Lost my owner's manual for my TIMEX T307S clock radio.
You can download the user manual from this link
http://www.timexaudio.com/pdf/T307_IB56281_07.pdf
SOURCE: instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
