You can download the drivers and software for your model directly from the Canon website.
Canon Support Drivers ZR45MC
SOURCE: Canon ZR200 mini DV Digital camcorder power is not coming.
First thing, clean your battery contacts, both on the battery, and on the camcorder. Make sure the battery is charged fully (measure it if you have a voltmeter). Make sure your power adapter is putting out voltage (again, measure it if you can) Try a spare battery, if you have one, to make sure the first one isn't just dead. Other than those things, you could have a faulty or broken power switch on the unit. That's about all I can think of offhand.
SOURCE: Canon ZR45MC Mini DV Digital... Problem
THE TAPE TRANSPORT IS OUTTA BALANCE. THESE GO ON TACKS AND IT IS OFF ONE.. VERY EXPENSIVE. AND VERY HARD TO DO. I AM SORRY
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
SOURCE: canon zr45mc chews tapes and cleaner cassette.
This happens because the "Pinch Rollers" are faulty. They will most likely have to be replaced. The ONLY thing that can be done, due to the delicate and complex nature of any DVR, they MUST be returned to a Canon, authorised, service center. Then ask for a "Quote" before proceeding with any repair.
SOURCE: My canon zr45mc will sometimes
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
