I already replaced the temperature censer when it was flashing F3 It worked for a few hours and now it's flashing F5.
SOURCE: F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Defective touch pad or membrane
Replace touch pad or membrane (usually the touch pad)*
F1
Watchdog on board
Replace touch pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay board (if present) or bad oven temperature sensor
F3 or F4
Open or shorted oven temperature sensor
Replace oven temperature sensor
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
Check for proper voltage
F7
Function key shorted or stuck button
Replace touch pad or clock assembly (also called the ERC) or un-stick button
F8
Analog/Digital supervisory
F9
Door latch supervisory
Check door lock circuit or replace clock assembly (also called the ERC)
F0
Function key stuck
SOURCE: error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open
or shorted
Replace
oven
temperature sensor
F5
Hardware
Replace
clock
SOURCE: My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
SOURCE: My Maytag oven (CWG3600AA8) keeps
Hello, joe
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
