Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
A
Anonymous Posted on Apr 26, 2014
Bose sounddock no sound - Bose SoundDock digital music system Docking Station for iPod - White (35703)
5 Related Answers
Anonymous
  • Posted on Nov 24, 2009
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Anonymous
  • Posted on Dec 03, 2009
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Paul Curtis
  • 51 Answers
  • Posted on Feb 22, 2010
SOURCE: I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
Paul Curtis
  • 51 Answers
  • Posted on Aug 16, 2010
SOURCE: Bose Sounddock failure
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original. Try the PSUif you can. The click is the PSU shorted that can be caused by a fault n the sound processor. Invebo will repair it for you too.
Anonymous
  • 17 Answers
  • Posted on Mar 09, 2011
SOURCE: Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
I am looking for an IC ior p833 for Bose SoundDock III please.
Question edited for clarity.
Direct from Bose
SoundDock® III Speaker - Bose® Product Support
https://www.bose.ca > products > bose_speakers_support
Discover product support for your SoundDock® III speaker. Learn how to operate your product through helpful tips, technical support info and manuals.
or here
Can a Bose SoundDock be repaired?
We offer refurbishment and repair of the dock. ... All docking connectors are replaced. The Bose SoundDock is a classic and is still the best on the market so it is one of the few things that are worth repairing.
day turn around repair and upgrade service for the Bose SoundDock.
1helpful
My ipod wont play in the bose sounddock. tried shutting off the ipod. dont think my sounddock has an on/off switch. did unplug all pieces
We have an HCL desktop computer. Though we had loaded Ac97 Sound Driver still the sound is not coming (totally soundless) Can you suggest what to do?
3helpful
2answers
With my ipod dockes I am getting a distorted sound
Did you get this solved??
I am having the exact same issue!
6helpful
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
