Check with Sears Parts Direct.com
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
SOURCE: need to know the kind of oil or grease that goes in transmission
engine oil is sae 30
the the gear box I think is a 90wt
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
