Dell Dimension 4600 PC Desktop Logo
A
Anonymous Posted on Apr 25, 2014
How do I remove all my personal information of my dell dimension 4600
How
  • Carl
    Carl Oct 14, 2014
    You don't have to destroy the hard drive. You can create a new user account, then log into the new account and from there delete your old user account(s). Then download & run CCLEANER to wipe out all the unused space on your hard drive (you can set it to 3 or 7 passes for secure over-write, this will take sometime).
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
  • Posted on Oct 09, 2014
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
340691
Points
2289
Remove the hard drive and destroy it.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jan 05, 2008
SOURCE: dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Anonymous
  • 667 Answers
  • Posted on Jul 08, 2008
SOURCE: ethernet driver for dell dimension 4600
Hi stefyboy - Below is a link where you can download your driver. After you get to the page just make sure it says Windows XP as the operating system. Then scroll down and click on the + next to where it says network. You want the intel 10/100 driver. I've included a few a ways to install it. If your kinda new to this the easiest is the download to desktop method and just remember where it unzipped it to, you can always move it to a driver directory where you can keep all your drivers for the future.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be glad to assist you further. Thanks.
Jeff
Hard Drive Installation (via WinZip) with HTML Pop-Up Window for R67150.EXE
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save this program to
disk (Windows XP users, click Save) and click OK. The Save In: window
appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
name icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled R67150.EXE.
The Self-Extractor window appears.
2.Click OK or Continue.
The Self-Extracting Driver Installation window appears and prompts to
extract files to C:\DELL\DRIVERS\R67150.
3.Leave all of the default settings and click Unzip or OK. If the directory doesn't exist, you'll be prompted to create one. Click Yes. A Self Extractor window appears and indicates C:\DELL\DRIVERS\R67150 files were
extracted.
4.Click OK.
Follow the on-screen installation instructions in the window.
HTML Pop-Up With Install Now Button
1.The Dell Software Installation Documentation window appears.
2.Click the Install Now button. A File Download window appears.
3.Click Run this program from its current location and click OK.
The Security Warning window appears.
4.Click Yes. The InstallShield Wizard window appears.
5.Follow the on-screen instructions.
Anonymous
  • 233 Answers
  • Posted on Jan 18, 2009
SOURCE: internal battery needs to be replaced on my Dell Dimension 4600.
Unplug the computer. Remove the side cover. This is probably held on by two or three philips head screws on the back left edge of the unit. On the motherboard, look for a flat, round, shiny piece that resembles a nickel. This is the battery. There should be a small metal tab that holds it in place. Push on the tab and the battery should pop out. Note the orientation of the battery and replace with a new one in the same position.
Anonymous
  • 137 Answers
  • Posted on Sep 03, 2009
SOURCE: My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Testimonial: "Very detailed advice, thanks! I believe my motherboard is bad, after testing with your suggestions. "
Anonymous
  • 51 Answers
  • Posted on Sep 30, 2009
SOURCE: system recovery dell dimension 4600
you need to press the
ctrl + F11 as soon as you see the Dell logo screen when you turn on the computer.
the trick is. as soon as you turn on the computer, press and hold on the ctrl key then keep tapping the F11 key.
I need to remove all my personal information off my dell dimension 4600 how do I do it
Depending on how secure you need the data erased: The easiest way is to create a new account with a different name (with administrator privileges). Logout of your account, login to new account, delete your account and all data associate it. Your data MIGHT be recoverable with recovery software but WON'T be readily available to anyone without recovery software. If you need ABSOLUTE data erasure - remove the drive and melt it with a blow torch. Don't want/need to destroy the drive? You can remove the drive, connect it to another computer (either internally or externally by using a USB adapter), and overwrite the drive with all zero's. Beliefs are that the more times you overwrite the drive, the less recoverable your data is. But more recent studies show that a single wipe is all that is required for modern drives.
Dell Dimension 4600 audio
Hello download the driver here:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600
The c model:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600c
Here could be several versions of the driver so you just have to try.
Good luck
The monitor is blank (pale gray color). No information How can I find a monitor to replace it? The computer is a Dell Dimension 4600 series. I don't know what are the video characteristics of this...
Hello
OK, the package comes standard with a 17 inch screen(CRT). So, basically you have 2 choices, you can either buy a replacement CRT screen or you can buy LCD, these are the cheaper options available at this moment.
I would personally go for a LCD screen. the size is a personal choice, but i will not go any bigger that a 23 inch with the graphics card installed.
You will be able to buy it at almost any computer store, and it is cheaper than you think.
Please let me know if this was sufficient, if not, i will try and better explain myself.
Kind regards
Andrea
2answers
Soundcard for dell 4600
There are 4 different versions sound card drivers for this Dell Dimension model (4600).
Go to 4600 and select Audio then download which version from the list for your desktop.
Till next time, take care of your desktop.
4helpful
2answers
What type of CMOS battery does a Dell Dinmension 4600 use?
Hi friend,
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
If you have to repeatedly reset time and date information after turning on the computer, replace the battery. You can read anything about your dell dimension 4600 PC like....how to change the battery click on LINK
With Regards
Avnish Kumar
2answers
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
1helpful
RAM for Dell Dimension 4600
Heres a link from DELL,it has all the correct parts and manuals for you,
This section is titled Removing and Installing Parts by DELL.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/parts.htm
Your memory is DDR Ram.
1helpful
Cover removal Dell Dimension 4600 Desktop
Description of how to remove the cover for this model can be found at the following link:
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/remcvr.htm#1084976
2answers
Seeking a diagram of what all the inputs on the rear of the 4600 are...duh
This Link below will take you to an online service manual for the Dell Dimension 4600. Click Here
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
