Busted power amp section
Here's a link to the service manual from Crown:
http://www.crownaudio.com/media/pdf/legacy/130352-1_10-02_ce1-2_serv_revd.pdf
SOURCE: Crown CE1000
Cuold be the final power amp ic. Might be imput transistors to that channel. Its possible to have a cold solder joint on pcb.
Look close at board with good light and a mag. glass to see if any foggy looking joints and heat up with soldering iron then dab with fresh solder.
Good Luck
BigRED
SOURCE: Should the fan run when my crown ce1000 unit is
It runs in response to certain thermal conditions.
SOURCE: fan running
This is a very sophisticated amp and it will turn the fan on at various speeds when it feels the need for it. Of course, if it's running REALLY hot, going into thermal protection and/or posting a fault you might take a look at it to see if it CAN turn (no obstructions).
Testimonial: "Thanks for the help that explains a lot."
SOURCE: CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Testimonial: "APPRECIATE THE HELP"
