Question about Sony PlayStation Video Game Consoles & Games
How can get infinite HP for xenosaga episode 3 while fighting bosses
I've heard that Tom Hanks appears in the series. Where?
He has a small cameo in episode 5, as a British paratrooper officer during the celebrations that follow operation Pegasus. He also can be seen in episode 9 "Why We Fight". While Easy Company's drive to Thalem they pass a scene, where two french soldiers execute 3 German POWs. He is the French soldier, who executes the prisoners.
Sep 04, 2016 | Band of Brothers (2001)
Infinite ammo and infinite life
There are currently not cheats for Infinite ammo or life. Unfortunately there aren't any "cheat codes" for this game, but there is an alternate ending. In the end when defeat the final boss, you must run from explosions. If you let the explosions kill you, you will get an alternate ending.
May 04, 2011 | SNK Metal Slug 4 & 5 Combo for PlayStation...
I need a walk through can you tell me where to find one? also, is ther any cheats i should know about
hi there,
      try the following site if you need any sort of faqs--www.gamefaqs.com-- .as for that game,there are no cheats. gud luck
May 26, 2010 | Namco Xenosaga Episode III for PlayStation...
How can i get to world 4 and 7 of the supermario game inmy nintendo DS lite
Fight the Bosses in world 2 then 6 as tiny Mario (Blue Mushroom) and win then Mario will jump down to the other floor below and then the sign will turn around and say "World 3" "World 7"
Dec 31, 2009 | Nintendo Video Game Consoles & Games
I want to know the key code for pokemon stadium 1 and 2
DE000400 0000 Enable Code (Must Be On)
P1 1st Pokemon Codes
800AE562 03E7 Infinite HP
800AE580 00FF Infinite 1st Spell
800AE581 00FF Infinite 2nd Spell
800AE582 00FF Infinite 3rd Spell
800AE583 00FF Infinite 4th Spell
800AE584 0063 Level 99
810AE586 03E7 Max HP
P1 2nd Pokemon Codes
800AE5B6 03E7 Infinite HP
800AE5D4 00FF Infinite 1st Spell
800AE5D5 00FF Infinite 2nd Spell
800AE5D6 00FF Infinite 3rd Spell
800AE5D7 00FF Infinite 4th Spell
800AE5D8 0063 Level 99
810AE5DA 03E7 Max HP
P1 3rd Pokemon Codes
800AE60A 03E7 Infinite HP
800AE628 00FF Infinite 1st Spell
800AE629 00FF Infinite 2nd Spell
800AE62A 00FF Infinite 3rd Spell
800AE62B 00FF Infinite 4th Spell
800AE62C 0063 Level 99
810AE62E 03E7 Max HP
P2 1st Pokemon Codes
810AE65E 03E7 Infinite HP
800AE67C 00FF Infinite 1st Spell
800AE67D 00FF Infinite 2nd Spell
800AE67E 00FF Infinite 3rd Spell
800AE67F 00FF Infinite 4th Spell
800AE680 0063 Level 99
810AE682 03E7 Max HP
P2 2nd Pokemon Codes
810AE6B2 03E7 Infinite HP
800AE6D0 00FF Infinite 1st Spell
800AE6D1 00FF Infinite 2nd Spell
800AE6D2 00FF Infinite 3rd Spell
800AE6D3 00FF Infinite 4th Spell
800AE6D4 0063 Level 99
810AE6D6 03E7 Max HP
P2 3rd Pokemon Codes
810AE706 03E7 Infinite HP
800AE724 00FF Infinite 1st Spell
800AE725 00FF Infinite 2nd Spell
800AE726 00FF Infinite 3rd Spell
800AE727 00FF Infinite 4th Spell
800AE728 0063 Level 99
810AE72A 03E7 Max HP
Sep 27, 2009 | Nintendo 64 Console
Boss digital delay pedal DD-3 won't stay on
I have seen a somewhat similar problem before. A switching diode had become faulty and needed replacement. I have no way of telling you where to look but if you have a volt ohm meter you can test them individually without removing them. The diode you are looking for would be in the circuit which connects to the switch. Use your probes to get a reading in one direction(one probe on each end of the diode) and then a reading with the probes reversed. If the readings are close or infinite in both directions you will want to unsolder the diode (making careful note of its orientation) and test it again. If the readings are still the same or close you will need to replace the diode. I forgot to mention to use the 2000 ohms resistance scale or the diode test function if you have one. Hope this helps.
May 03, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
How do i get to world 4 and 7
You need to beat the bosses of Worlds 2 and 5 as mini Mario.
When you beat them normally, you should notice as Mario runs into the next room, there is a tiny path under the ground. Those paths are to Worlds 4 and 7, and only mini Mario can fit in there.
So when you fight the bosses, either have a mini mushroom in reserve or go into the fight as mini Mario, then in order to hurt the bosses, instead of regular jumps, you have to do a ground pound on them. Three ground pounds will do it, but make sure you are mini Mario at least on the last attack, and then you're off to World 4 and/or 7!
Feb 18, 2009 | Nintendo New Super Mario Bros. for DS
The simpsons game cheats for playstation 2.
Hi www_julie,
Heres a walkthrough for you> Museum of natural history (Bartman Begins)
Second level, here we go!
Analysis
Playable characters: Homer and Bart
Enemies: Security Guards, Dolph, Kearney and Jimbo
Ammunition: Light Bulbs
-NEW ABILITY- bartman
After the cut scene run right and jump the gap, break the barrel for a Krusty
koupon then slide down the Zipline, past the helium bottle and climb the wall
and get the token. Climb the ladder and activate the switch (X). Now you are
homer, use the fallen stalactite to jump the gap and climb the ladder NEW
CLICHE- You should now have unlocked the cliche "switches and levers" and
jump on the pressure pad. When the gate recedes climb the ladder to the next
area. You will now fight a few guards, usually 1 at a time; they will take 4
hits to kill. Activate the pressure pad to make the blocks in the wall come
out, you are now Bart again. Jump on the blocks then the statues knees to get
the koupon, return to the blocks and jump onto the statues bust and then the
higher blocks. You will now come to a big gap, use the bartman cape glide
(hold B while jumping) if you're lucky you will get the koupon while gliding.
Pull the lever and the bridge will extend, you are now Homer! First cross the
bridge, pass under the statues legs, beating any guards in your way but DON'T
jump on the pressure pad, just pass it and pick up the duff cap on top of the
mini statue that is in half. Now activate the pad. You are now Bart, Run
along and jump on the blocks, going LEFT, you will have to glide to one of
them, then climb the vines on the hall, jump off the roman helmet and onto
the sword, kill the guard and get the koupon. Now proceed back onto the
blocks but this time go right and onto the platform, kill the 2 guards and
hold up on the + pad and shoot(A) to hit the target, then jump into the gap.
Straight away run off the brontosaur's back and get the koupon in front of
the mini-T-Rex then back on the bronto's back, onto his head and glide onto
the canopy jump onto the nearby pterodactyl and then over the mini-T-Rex, or
onto his head for the koupon, then pull the switch to extend a tongue from
the mini-T-Rex's mouth. You are now Homer. Climb the ladder and jump off the
bronto's tail onto the tongue, then at the tar pit (don't worry it's not real
tar!)jump onto the bone in the middle then to the other side. Kill any guards
on the way and activate the pressure pad !NEW CLICHE! You should now have
unlocked the cliche "Pressure pads" You are now Bart. Go right and glide on
the draft onto the pterodactyl. Jump onto the pterodactyl to the left and go
down the Zipline, continue left until you get the Krusty koupon, then retrace
your steps to the volcano and on that pterodactyl, go right and pull the
lever and get ready for the first boss fight of the level!
BOSS FIGHT ANALYSIS 1/3
Hits to kill: 4
Attacks: Slingshot
Description: A punk-looking character, he has a brownish-green baggy shirt on
and black shorts, his hair is draped down the right side of his face.
Shoot him to start the fight(to shoot down hold down on + pad and press A)
then when the lights go out shoot the targets, then when the lights return,
shoot him, after about 4 hits(I used light bulbs, with normal ammo it might
be different) then go right. Straight when this area starts, turn around and
get the Krusty koupon, then go right, shooting the targets to let Homer
proceed, as you can't go through the doors without him going first. Ok pause
the game just after the castle area as the is an important target here, while
Homer is destroying the fence, run forward and hit the 2 targets, as the one
under the cannon will release a duff token for Homer, then prepare for the
boss fight!
BOSS FIGHT ANALYSIS 2/3
Hits to kill: 5
Attacks: None
Description: A bald kid wearing a white shirt and black shorts.
As the fight goes on, you will see 3 doors with Homer, Kearney or Ralph
behind them you must shoot the target underneath Kearney to hurt him, after
about 5 hits he will fall, letting you leave. In this next room, you must use
the planets to get to the top, there will be a bit where you must use a small
meteor to get to a ladder then climb the ladder onto Jupiter, then jump onto
Saturn's rings. At this point there will be 2 planets, 2 flying saucers and 1
rocket. Ok, this is all for: 1 koupon and the best spot to hit Jimbo. Jump
onto the first planet, then onto the first flying saucer, slide down the
Zipline then drop off of it right on top of the rocket, then use the rocket
smoke to glide onto the second saucer. While on the second saucer, get the
Krusty koupon, now for the boss fight!
BOSS FIGHT ANALYSIS 3/3
Hits to kill: 20-21(I used normal ammo for this; it may take less with the
light bulbs)
Attacks: Green plasma orbs
Description: Wears a woolly hat, black shirt with a skull emblem on it and
blue jeans.
Ok, this fight is easy enough if you got the light bulb, either way, use the
automatic slingshot (hold A) he is just above you so you will have to shoot
up.
End analysis:
7/9 Duff Beer Caps
18/18 Krusty Koupons
4/27 Video Game Cliches
Happy Gaming :)
Dec 22, 2008 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
