SOURCE: lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
SOURCE: lxczpswx.exe error when booting up windows
Try this:
Click on START, click on RUN
A small window opens, delete anything that may be typed in it and then type this -
regsvr32 /u c:/windows/system32/spool/drivers/w32x86/3/lxczPSWX.EXE
click OK
SOURCE: aioc.exe
What you need to change is your screen resolution to either 800 x 600 or to 1024 x 768 (in your desktop settings)
What is happening is that your Lexmark all-in-one center doesn't think your monitor can handle the program (or something to that effect).
You will NOT have to restart your computer either.
Just restart your Lexmark All-In-One program and you can start scanning.
SOURCE: Lexmark X 1250 All-in-One
Thank you for showing your interest. The solution was very simple actually, but I forgot by the time. One of your team mates adviced me the following;
lxczbmgr.exe is a Lexmark 1200 Series Button Manager from Lexmark International, Inc.
belonging to Button Manager Executable
Uninstall and do the driver download again..... install the file and DO NOT connect
the printer to the PC until the software tells you to do so.
This was the whole clew!
Yours sincerely,
Marja
SOURCE: aioc.exe
This is what i did to fix the problem
>I went to Dir "C:\Program Files\Lexmark 1200 Series"
>I then found the file (aioc_app.ini) I cut this out and pasted it to my desktop.
>Then I opened up the lexmark all in one center program and there you go it was working.
> placed the .ini file back in the folder
Tried this twice and got the same results both times.
