SOURCE: singer 251-2 industrial sewing machine
It was a tough find but here is your manual:
http://www.bestneedles.com/catalog/singer/Singer%20Instruction%20Manuals/251-Class-Inst.pdf
SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
SOURCE: I need instructions to Thread a White Super Lock 534 Serger
I hope this helps. there a lot of other vidios you can try as well. DFD
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
