Paper feed motor problem • LOCK ALM signal remains high for 1 s, 1 s after the paper feed motor has turned on.
Causes
Poor contact in the paper feed motor connector terminals. Defective paper feed motor rotation control circuit. Defective drive transmission system.
Remedy
Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper feed motor. Check if the rollers and gears rotate smoothly. If not, grease the bushings and gears. Check for broken gears and replace if any.
This question (which is factually not a question) needs more information. When does this happen?
Possibly an updated code. I can find E07 for Kyocera which means the printed document size/format does not match current paper size/format. Like you want to print A4 on Letter paper.
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here: Kyocera Error codes
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
HI,possible codes for kyocera printers are available at the below link, if the code you are trying to fix is not on the list, i think you will need to contact kyocera customer service..
