Try this one If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
how to unlock samsung E1272 - android-recovery-mode1.jpg/android-recovery-mode1.jpg" alt="android-recovery-mode1.jpg" class="h_mi" />
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at thehow to unlock samsung E1272 - android-system-recovery-menu.jpgc="/uploads/images/android-system-recovery-menu.jpg" alt="android-system-recovery-menu.jpg" class="h_mi" />
Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its how to unlock samsung E1272 - android-wipe-data-factory-reset.jpgl be erased.
If your device freezes at any point, hold down the Power button until it restarts.
If You Can Boot
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option ohow to unlock samsung E1272 - android-backup-and-reset1.pngoid or tap Privacy if you're using Android 2.3.
If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
(There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
note all data will be deleted
