SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
SOURCE: lg wm1832cw front load washer
One of 2 things may be causing the loud noise. Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive). Either way, you will need a qualified LG technician to diagnose and repair the problem.
SOURCE: LG Front Load Washer Problem
The washer is not leveled correctly. You will need to adjust the front feet to level the machine. Run a load of clothes in the washer. When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner. If the noise quiets down on either corner of the machine, adjust the legs on that side.
SOURCE: Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
Try adjusting the load size, and make sure the unit is level.
