Can I replace the molded fuel line on my Mac 605 chainsaw with an unmolded type?
Yes, or you can just order the correct one using the resources below:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: mcculloch 4600 chainsaw fuel line routing
Shouldn't be that hard to do. Possible paths 1) Run hose from tank fitting to Carb fitting. 2) Run hose from tank to shut-off vale to Carb 3) Run hose from tank to shut-off to prime to carb 4) run hose from tank to shut-off to prime to filter to carb. Omit any item not on your saw.
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
SOURCE: My McCulloch chain saw fuel line has evidently
Yes you can do a generic one, just get to any chain saw rea pair shop and tell them your problem or go to Mcculloch.
SOURCE: how to replace the fuel primer bulb and fuel lines
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
SOURCE: I have a 18" mcculloch mac 5 evolution Chainsaw
You should run the saw on a 50-1 fuel oil mix, with an oil from a known chainsaw manufacturer and recommended for 50-1, this machine was an Italian built product sold under many different model names, Titanium 460,Partner 538, California, i am sure if you surf the net you will find one. If you cant find one post me your e mail address and i will send you one.
