SOURCE: Kyocera 2550 Scanner I'm unable to connect via browser
Check the PC that you are trying to scan to amd make sure that the Scanner File Utility is up and running. You can check this by looking for the scanner icon in the bottom right corner, if it's not there click on start, all programs, scanner user software, scanner file utility, click on Scanner Utility to bring it back up, it just might have gotten closed accidently. If none of this works go into the control panel and click on firewall amd make sure file and printer sharing is checked, if it is you may have to turn Windows Firewall off to make the Scanner work.
