I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
To use the HP Hard Drive Self Test, follow the steps below.
NOTE:
If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
Shut down the computer if it is running.
Press the power button to turn on the computer.
Press f10 when the HP/Compaq logo displays.
After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
Select HDD Self-Test options .
Press enter to display a list of HDD/Self-Test options.
Select Notebook Hard Drive and then press f10 to display an Estimated test time .
Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If any test
fails , contact HP for instructions on how to order a replacement hard drive.
If all of the tests pass, the hard drive is not damaged. As a rule, HP
does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
