I removed casing cover drained and cleaned residue put everything back together now e17 is on display, removed everything again but the but lid will not unscrew fully it gets to end of threads but won't let go
SOURCE: I just bought my washer
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
SOURCE: Bosch series 300 washer: E:04 error; how to remove pump cover
You can get that cover off, by prying it up at the bottom and spinning the thing clockwise. then there is a large hand turnable plug inside.
Once you turn it water will start leaking out, you'll have to get in and pull out the crud from the pump screen there to clear the jam. Good luck!
SOURCE: My Bosch 100 series won't drain or spin. How do I
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: I had a E04 error
Hi, check to see if the washer is leaking where the inlet hoses are connected to the washer and to the faucet. Make sure both ends of both inlet hoses contain the hose washers that came in the parts bag with the washer. Make sure all the connections are tight. If necessary, tighten the connections to stop leaks.
Also check to see if either the hot or the cold water hose is leaking either along its length or where it attaches to the faucet or to the water inlet valve. In the simplest case, you may simply need to tighten the hose slightly at one end or the other. A pair of pliers can be used to tighten the hose fitting, but be very careful not to over tighten at the water inlet valve end because here the hoses screw onto plastic or nylon threads that can be stripped by over tightening..
SOURCE: Bosch Vision 300/500/dlx Series Clothes
Im getting an error e13 message and don't know what to do
