Schwinn 220 Recumbent Exercise Bike - 2012 Model Logo
A
Anonymous Posted on Apr 24, 2014
Why will the resistance level not change - Schwinn 220 Recumbent Exercise Bike - 2012 Model
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
https://service.nordictrack.com/CustomerService/contactUs.do
Slight noise in level 1 resistance, then resistance won't change at all
if you are using the Normal charger AC, try to see if are O.K measure with DMM the output(see the laber for Output voltage VDC)
2) If you are using the Batteries , replace by new ones Type ALKALINE, very important. Clean very well the springs and tight, use electronic cleaner contacts, see if there are some wires loose or desolder.
3) If everything is o.k See for the small motor inside (this regulate the resistance) if working good, or the steel cable is broken, or missing or the motor is faulty, replace or repair.
Blessing.
[email protected]
cell+whatsAPP:+50588611441
Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
5helpful
Resistance level does not change anymore. What is
I fixed a problem with my Schwinn Elliptical 430 resistance level not working. When I would change the level anywhere from 1-16, I could hear the motor turning, but there was no change in resistance. If you hear the motor moving, then try this:
Using a Phillips screwdriver, remove all the screws on the left side of the large plastic cover (left side if you are standing on the machine). When all screws are removed, you can pull the plastic cover off, and move it towards the back of the machine without having to disconnect any of the metal bars. (The bottom two screws are a little tricky to get off. Hold the housing in place, don't let it sag, in order to get them out.
Look inside the unit and find the magnet, which is a rounded, brake-show like piece that is close to the flywheel, on the top half of the unit. There's a cable from the motor that goes upward and is attached to the magnet housing.
If you try to adjust the resistance level now, you should see cable move up. This is supposed to allow the magnet to move closer to the flywheel and increase resistance. In my case, the magnet was stuck and wouldn't move upwards. When I gave the magnet a little push with a screwdriver, it popped up to where it should be.
To solve this issue, you will need two wrenches. You must go to the opposite end of the magnet, towards the front of the machine, and you will see it's connected with a nut & bolt. Using a couple wrenches, hold the bolt, and loosen the nut about 1/4 turn.
This should lessen the pressure on the magnet housing and allow it to move freely and not bind. Reassemble everything. Lie the elliptical down on it's side to allow the screws to fall into the holes easier.
Once it's all back together, you should find that the resistance level works again!
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
