SOURCE: door alarm keeps sounding even though doors aren't ajar
ginad, L&G missed the tolerance a little on the door switch. They do make a kit to correct the problem, I believe it's a little gasket that fits under the door switch. I use a plastic stick on, on the door itself, to solve the problem. As long as it's under warranty have the replair co. fix it. In the meantime just use a piece of tape to cover the door switch.....Catriver...post back
SOURCE: door alarm
It depends on the model you have. Look on the door panel and look for the control button that shuts off the alarm. Press and hold the button 5 to 10 seconds and that should shut it off. If you don't have that feature, then there's nothing to disable the alarm.
SOURCE: LG Bottom freezer refrigerator LRFD25850ST
You will have to buy a new board to solve it.
Sgt 48
SOURCE: door open alarm will not shut off
Try pressing the cut off button manually while the door is open. It sounds like the switch may be bad.
