Sewing Machines Logo
A
Anonymous Posted on Apr 24, 2014
How to fix a broken Needle clamp on viking 936
I can no longer insert a household needle in the left side of my huskylock 936 serger. How can I fix a broken needle clamp? The right side needle is fine. I'm not sure how the left side got broken.
  • Donna Sep 14, 2014
    Did you ever get this resolved? I'm having a similar problem... Different side.
deborahcha
Level 2:
Novelist:
  • Husqvarna Expert 371 Answers
  • Posted on Oct 16, 2014
deborahcha
Husqvarna Expert
Level 2:
Novelist:
Answers
371
Questions
0
Helped
147679
Points
481
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website - http://www.husqvarnaviking.com/us
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Jul 24, 2009
SOURCE: user guide Overlocker/serger Husquvarna Viking Huskylock 905
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Anonymous
  • 152 Answers
  • Posted on Oct 10, 2009
SOURCE: I am looking for an instructional video or DVD for
This link will give you a video of your machine to watch, it's awesome!
http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Anonymous
  • Posted on Dec 01, 2009
SOURCE: Huskylock - 530 - Serger won't create 'loop'
My stitch is good, upper and lower correct, but it will sew along and skip stitches. What do I need to do?, am good at repairing things on it all these years, I havent used it a lot the last few years, but it has started this skipping problem.
Anonymous
  • 51 Answers
  • Posted on Sep 17, 2010
SOURCE: Can't find the manual for the Husqvarna Viking
http://www.tradebit.com/filedetail.php/87838064-husqvarna-viking-emerald-116-118-122-user
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Sep 26, 2010
SOURCE: husqvarna 936 coverstitch is skipping stitches in
sounds like the needle is damaged-time for new needle
2answers
936 Huskylock needle bar does not move up and down.
First, make sure the machine is engaged to sew. some machines,
have a knob inside the flywheel on the left side that disconnect the sewing mechanism to wind a bobbin without the needle bar moving.
Cheers,
Embroidery Services
San Diego, CA
How do you sew with three needles on huskylock 936. I can't seem to find a third spot for a needle.
A 936 has 5 needle positions. C & D are in the back position and AB&E are in the front position. Check your user manual for diagram. you can view, print, or download the manual from the viking website - http://www.manuals.husqvarnaviking.com
I also have the same problem for the cover stitch i put the needle in the holes for A and B and unscrew and slide the needle in flat side of needle to back but the needle does not go up all the way and i...
The best needles to use in the Vik serger is the Schmetz brand. Also, loosen the right needle a bit to make sure you are getting the left needle up all the way, tighten left, then tighten right.
My Husqvarna Huskylock will not catch the 3 thread overlock when sewing. I am sure it is threaded right. Hope you can solve this!
First thing to try is a new needle and make sure it is inserted into the needle holder all the way! There is a small opening in the needle clamp. Look closely at it when you're inserting the needle and you will see the top of the needle through that hole as it reaches it's top position. Also check the needle plate, are there 2 small needle like pins in the plate? If one of them has broken out of the plate, you'll have a hard time getting it to sew correctly. If it is missing one, you need to buy a new plate. If all of that is correct and it still doesn't sew properly (and you're sure it's threaded right), a trip to your service tech will be needed.
Huskylock 936 error code
This will also occur if the "needles" and "loopers" lock up as though threads are tangled and binding the machine. If needles and loopers move freely when manually turning the handwheel counter clockwise, you probably need to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
2answers
Change needles
Look at the top of the needle where it is inserted in the needle holder. There are spaces for 4 needles - A B C and D. Most likely you are using the backmost needle positions - C & D. Look on the needle holder there are little wholes which are sctually screw holes that can be loosened and tightened using a Torx 6 screw driver (available at Sears) if you no longer have the needle changer screw driver. By turning the screw, the needle is eeither tightened or loosened. Be careful that when you loosen the needle it does not fall through the machine. Put a slip of paper on the needle plate below the needle to catch the needles when they are losened. You have a great machine in the Huskylock 936 and well worth keeping it serviced by a certified Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
2helpful
2answers
Hi there, my husqvarna 936 is jamming slightly when i turn the hand wheel and when i use the pedal it works but their is a load catching noise can you help me plz
Hello, The first thing to do with a serger is to change the needles and take the thread off the machine and rethread it. The 936 can sometimes "fight" you a little when it comes to getting the needles up in all the way. It's critical that they are inserted all the way up in the needle clamp. Check to also make sure the N/R lever is in the N position. Check the needle plate, are the "needle like" pins still attached to the plate? If your serger jammed, sometimes the thread breaks the pin supports out of the plate. They are very important when it comes to stitch formation.
2answers
How do I remove the needles A & B
Needle removal is pretty simple. The foot was already removed on my wife's machine. Am not sure that was necessary, but if it is it is very simple....single screw. Once that is off, get out the small allen head driver from your serger tools and loosen both needles...and remove them...and replace with new. Maybe a two minute job. The needles seem to be a generic size....available at WalMart.
2answers
Viking 936 uneven stitches with loops
Sounds like either the loopers need adjusting or there is a twist in the needle bar. These are all things that have to be done by a certified husqvarna viking service technician via an authorized HV dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
