You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
I've never encountered that problem, but the manual says: Make sure remote Transcribe indicator is extinguished. Move the Transcribe switch to Local position. Locate letter to erase with either [Prev. Ltr] or [Next Ltr]. Simultaneously press [Currnet Ltr] and [Erase] buttons to erase letter appearing in Item Status display. A tone plays and Erase LED lights briefly. Letter is automatically deleted.
To erase all Transcribed Letters: Make sure "In Use" Transcribe indicator is extinguished. Move Transcribe switch to Local position. Simultaneously press the [Finished Ltrs] and [Erase] buttons. Tone plays and Erase LED lights briefly. Good luck!
Do you know how to determine the total minutes on the machine? I have 2 that I want to sell, one of which is on eBay. Thanks.
You should setup 2 different work types. Have the dictator select the work type prior to dictating the job. The higher priority work type should be sorted higher up in the pool script for Enterprise Express. If this is a Straight Talk, simply have the dictator select work type 2 (priority) and that job will come to you first. If you need help setting up a pool or a pool script please contact timtrent at hotmail dot com.
Hello I can help but i need more info about your greeting we can try to set up really simple if is not that critical for you we can live it with a beep and start to record after the beep please let me know you can contact service at Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
