Need to change bios,or system boot order,to boot to disc,to install operating system
Press and hold F11 or F12 when you turn on PC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/yordan_0946180d068c57d5
SOURCE: need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
SOURCE: Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
SOURCE: emachine boots to bios with a new hard drive installed
well your jumper is probably set to boot right to bios. you have to go into your comp and move the jumper to its origional location.
SOURCE: emachine T5212 will not boot up unless operating
Restart, press DEL to enter BIOS and change the boot priority/sequence to boot from your HDD, second choice will be from CD-ROM and last from floppy. Next after saving the changes allow it to boot normally....sodeep.
SOURCE: i am trying to change my boot order on my emachine
instead of hitting the tab key, i would try hitting the F8 key, this one should get you into your bios. From there you should be able to go into your boot options (or startup) and you should be able to select using the arrow keys and the + - keys to change your preferred boot option//
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
