Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
A
Anonymous Posted on Apr 24, 2014
Tv will not power off with no picture after power surge
LG tv power surge
Don't touch the main TV board. Change the T-com board. The screen will come back to full size.
My satalite was disconnect and then back on well then my tv comes on and in a flash it's off will not stay on it has a picture.Dish said i need a surge protecter.
A power surge due to lightening may have damaged the switching power supply. You will need to change the power supply module inside the TV. Normally, such power supplies have surge protection built-in, however, some surges are too powerful and could damage capacitors and crystals in the power supply module.
Two vizio TV's with issues
Take them to a TV repair centre as they are complex to repair. You may find that your homeowner insurance will pay for the repairs if you can demonstrate that it was a power surge that damage them.
Power surge to Ns 24E200NA14 Insignia tv. Has power, backlight, sound but no picture
Yes it received a massive surge from the transfer. You would need to replace your Insignia or try taking it to a Bestbuy which is a Bestbuy brand to have them fix the unit. Also try putting it on a really good surge protector as well.
Had a power surge through my house tv picture went out I think there is still sound but no picture anysuggestions
make sure to plug in all major electronics and appliances to a very nice surge protector. If you have tried the TV in other outlets that you know work, and it doesnt display anything. It is probably power supply.
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Hi, my sony trinitron Wega KV-32Hs500 will not come on. The stadby light blinks 6 times. I was able to get it on yesterday after repeated turn on, but now won't come on at all. It was working great and had...
common problem. sony makes a power suplly service kit that will repair it. cheap. the power supply is very efficient but ver sinsitive to power surges. easy ans cheap. good picture is worth fixing.
1helpful
Very old Sony Trinitron
Hello gemdsimm,
You right, its cuased by power surge and you should contact nearest Sony service shop for proper repair.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
