I HAVE A KENMORE COLDSPOT SIDE BY SIDE REFRIGERATOR. MODEL #106.54563300, SERIAL #SR0942820 MADE IN 2004. THE WATER DIPENSER FILLED WITH WATER RAN OUT ONTO THE FLOOR. IT IS NOT MAKING ICE ANYMORE. WHAT COULD BE WRONG?
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: kenmore refrigerator side by side model
Your fridge has a dual solenoid water valve - one side controls the water flow to the dispenser, the other to the ice maker. It's possible that one side burned out while the other is still good.
Here's a photo of what it looks like:
Here's a link to the replacement part:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/218658000/0046/253/Model-25358682890/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=25358682890&subCompDesc=Icemaker&brandDesc=KENMORE&modelDesc=Side-by-Side&blt=11
Before replacing the part, make sure the solenoid is in fact, bad. Get a voltmeter, and touch the probes to the electrical contacts on the solenoid, like so:
If the meter barely moves, the solenoid is bad.
If both solenoids test out OK, the other possibility is that the water supply line is kinked or clogged. Also, if your water dispenser has a filter (also on the back of the fridge), it might be clogged. My money's on the solenoid, though.
Good luck, and if this helps, please my answer!
Also, thanks to Zenzoidman for the pics.
Testimonial: "I've got someone to fix the problem, but this helps me understand what he might be looking for and what the part will cost. Thank you, Pat"
