Question about Turbo Air M3f19-1 M3 Freezer - M3F19-1
Should light be lit 1 thru 7 - Turbo Air M3f19-1 M3 Freezer - M3F19-1
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
What do the red light with abell shape which is lit up mean on my 18 year old tricity bendix freezer mean
It's a temperature warning that the freezer is no longer at the correct temperature. Check all is clean and working, door seal intact etc. If short of gas, probably time to get a new one!!! Bet it won't last 18 years this time though!
May 01, 2014 | Freezers
5 foot chest freezer by HOLIDAY, green light on bottom front not lit,less than one year old
I have the same issue, the green light on the bottom is not lit. Looked in manual and do not see anything about that. Freezer is working otherwise, everything frozen like it should be.
Apr 11, 2012 | Freezers
Frigidaire freezer CHEST FC263C USER manual. a red light is showing
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297079200en.pdf
Page 5 explains that the "Red" light is lit until temperature is reached.
Mar 06, 2011 | Frigidaire FFN15M5H Chest Freezer
What temperatures do the 1-7 reading on the temp. dial correspond to.
In all frdige freezers, 1-7 is -18 to -21 approx in the freezer and between 2 and 4 in the fridge. This may vary from system to system but not by much. Obviously, 7 is the coldest as this makes it the most difficult for t he thermostat to disengage.
Dec 10, 2009 | Frigidaire Freezers
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
Mar 05, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Red alarm Light Lit on my sERVIS CHEST FREEZER
Hello
Welcome to Fixya
My name is Huum,
The only thing for a consumer to do is check the fuse box or circuit breaker that they are on and or good.
And then you need service on location to diagnose and repair the failing part.
Other than this this is not a do it your selfer1
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 31, 2009 | Freezers
Green light
could be a possible short in the electrical
Jan 19, 2008 | Danby 5.5 cu. ft. / 156 liter Chest...
Turbo Air M3f19-1 M3 Freezer - M3F19-1 Logo
Top Turbo Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
