SOURCE: GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
SOURCE: I have a GE Profile
the ignitor switch for that particular burner is stuck in the on position. I may have some debris in it which is causing the problem. you could try to clean it using a blast of air from a keyboard air cleaner aerosol can, available at any office supply but most likely you will have to replace it.
SOURCE: I have a GE model jgp940 gas cooktop one of the
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Eric
SOURCE: Clicking sound coming from cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
