GE Spacemaker 1.7 Cu. Ft. Over-the-Range Microwave Logo
A
Anonymous Posted on Apr 23, 2014
Do you have a wiring diagram?
Mod# JVM1190BY002
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
What is the correct glass turntable part for the GE XL1400 microwave (Mod JVM1450BA001)?
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can enter the original part number
WB39X10003.
I'm getting an F3 fault code on my Maytag Mod. # CWG3600AAB. Everything points to replace the temperature sensor probe. With electrical off I have the oven pulled out but the wiring\harnesss of the temp...
Your temperature sensor has failed. You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
No power
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
3helpful
F9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
5helpful
NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
NEED OPERATION MANUAL FOR 1998 MICROWAVE-CONZECTION OVEN mODEL JVM1190BY002
Go to geappliances.com. Select "Use and Care Manuals" under the Search drop down menu. Type in your model number in the adjacent window and select "Go". Your manual is available in a downloadable .pdf format. I hope this helps you.
1994 Whirlpool Microwave Mod MH7115XBQ-2
You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 The most likely causes are: diagram 5, ref. 5 fuse diagram 7, ref. 2 thermistor diagram 2, ref. 5 control board If it's a problem with the control board, we repair them nationwide for $32.50. We also have important safety and disassembly information we recommend: http://tinyurl.com/yzjozk
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
