I did a hard reset on my xda atom, but then on the "DEVICE CLEAN BOOT....etc." message only shows and it won't start on the phone set-up/settings. What should I do. please do help me.
Then, I did remove the battery after it was hang up for several minutes and only the o2 logo shows.Then, I did remove the battery after it was hang up for several minutes and only the o2 logo shows.
I did rethe o2 logo showsmove the battery after it was hang up for several minutes and only I did rethe o2 logo showsmove the battery after it was hang up for several minutes and only
You can't post conmments that contain an email address.
At the expense of your data-loss,
atleast you get your device working back.
To perform a hard-reset on your O2 Xda Atom,
Keep pressed the POWER key, and then perform soft reset. After the device this leave everything and confirm that you want to hard-reset as shown on the screen.
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
try doing a hard reset you will lose all your data but it will return the device back to factory setting alot of these windows mobile device you have to do this with i have one and i hard reset mine once every couple months
confirm on hard resetting the device. Hard resetting the device will
You can perform two hard resets on this device. From windows. Click Start, Settings,then the Systems Tab,click Clear Storage, Type 1234 into the box and tap the yes button the phone will then reboot and reset.
OR Remove the back cover of the device and hold the call and end button on the fron of the device and reset the device by sticking the stylus into the small hole to the left side of the USB port the device will ask for confirmation to confirm press the enter key on the keypad and then the device will reboot and reset to factory settings.
Couple of things you can try to fix the issue, firstly try a hard reset
Try that and if it doesnt resolve the issue then we can try another solution
I have been using this phone for a little over a week, and am having a problem with
cprog.exe. After most phone calls, I have a message from windows saying that there was a
problem with cprog.exe, and it then sends an error report. I though that the phone might be
a little buggy at first, but this problem has continued and is very frequent. Is anyone else
having this problem?
This is the suggestion they provide on O2 website for such problems:
Perform a soft reset (PDA phone) or re-boot the device (Smartphone) and test again.
Perform a hard reset (PDA phone) or return to default settings (Smartphone) and test again. (read below before dong this)
Check that the application still fails to execute after you upgraded the ROM (OS) to the latest revision. If you haven't upgraded your ROM (OS) do so now and check again.
But before doing the hard reset, I suggest you try installing other camera software for windows mobile 5 and check if the camera still working (not a hardware problem). If its still fail, try the hard reset after backing up all you data.
i hope it will help your prob.
I was
me too damm
