Question about Sony PlayStation Video Game Consoles & Games
Sceptre tv i connected my playstation 2 to my Sceptre LED 40' tv through the three colored prong inlet thingy which I don't know the name of, but when I turn the tv channel to it, it keeps telling me there's no signal. How do I fix this? Can I fix this?
6ya staff
SOURCE:
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: playstation connection
LouB1,
You can hook up a PS2 to any TV made. You just might need a VCR or something else between the PS2 and the TV to get the Audio/Video Cable to work. Thats the Red, White and Yellow. If the Bush 14" has the red , White and Yellow RCA jacks and sais INPUT next to them. You definitely will get it hooked up.
Posted on Nov 30, 2007
Bilal Balagamwala
  • 64 Answers
SOURCE: tv reads no signal
does your tv has audio and video input???
Posted on Jan 17, 2008
Anonymous
  • 7 Answers
SOURCE: playstation three power problem
This is probably like the "Ring Of Death" that is included also with the Xbox 360. You might need to replace it. Have you been using it over a long period of time?
Posted on Apr 27, 2009
Anonymous
  • 49 Answers
SOURCE: playstation wont connect with av cable
is it just the tv screen saying no signal? if so you may still have your tv in HDMI mode if not then you need to go into the television settings
Posted on Aug 28, 2009
ikarras
Ioannis Karras
  • 23 Answers
SOURCE: sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Posted on Nov 01, 2009
Code for 40" sceptre tv with my ge 24944-v3 remote
The following 5 digit codes will work with your Sceptre TV.
10878
11217
11360
11599
10000*
The following 4 digit codes will work with your Sceptre TV.
0991
0000
0080
May 09, 2018 | GE Televison & Video
Tv antenna signal
You have to go into the menu on the tv remote that came with your tv and change the setting from cable to antenna.
Apr 09, 2014 | Sceptre Televison & Video
Dvd plays in black only
Be sure dvd player is correctly connected. If you connect the yellow video composite out the dvdto the input on the tv that is not yellow you are probably trying to watch it thru the component in . The component in is 3 wires green blue and red. if all three are not connected the picture will have no color. If you have 3 wire connection on dvd connect it to 3 wire in on tv the other red and white are audio.
Mar 15, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
My Sceptre TV randomly changes input sources
i have a sceptre Lcd tv model x40 the red light is on but when you push the power button it will not come on
Dec 31, 2013 | Sceptre X405BV-FHD3 40 in. LCD HDTV
How do I connect TV-ear 3.0 to a sceptre 23 bv-naga TV. I don't know were the audio out port is?
There are two plugs, a white and a red. Red is for Right, and white is Left. If you have a 3.5" stereo jack on your TV ear, then you'll need to find and adapter, as your television does not have a 3.5" output jack.
Jan 31, 2013 | Sceptre X23BV-Naga 23 in. LCD TV
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
I have a sceptre x42gv komodo 42 lcd tv for about three years, and lately the tv has had problems recieving the signal from the hdmi port to the DVR. it would show the picture in a very very dim light with...
Check the TV with another HDMI stuff, like a DVD player or a playstation 3 or something. If it still gives you the same problem then you know it's the TV. If it doesn't then it means something is wrong with your DVR. If it's the TV most likely you'll need to open it up and see which part is broken. A simple diagnostic is opening the back and seeing if any capacitors are blown. If those small capacitors are bulging that means they're toast and needs to be replaced. I know that you can also buy parts from Sceptre, so maybe see which part is broken and buy it from them to replace it?
Sep 16, 2010 | Sceptre X42GV-Komodo 42 in. LCD TV
Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Jan 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Video Game Consoles & Games Logo
486 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
