Apple AirPort Extreme Router Logo
A
Anonymous Posted on Apr 22, 2014
Flashing amber link light on modem flashing as well
Jason Yeaman
Level 2:
Guru:
  • Apple Expert 166 Answers
  • Posted on Aug 18, 2015
Jason Yeaman
Apple Expert
Level 2:
Guru:
Answers
166
Questions
0
Helped
31974
Points
831
It means there is something wrong with the configuration.
Use the the apple airport utility to find out what is wrong.
AirPort Utility
6helpful
FLASHING AMBER LINK IDICATOR LIGHT ON MY SB6121 MODEM
The SB6121 link light uses color to indicate the connection speed. Blinking means data transfer is taking place. Blue means that it's a 1000Base-T (High-speed Gigabit Ethernet). Amber means it's an older ethernet device. 100Base-T or 10Base-T Ethernet connection.
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Bottom lights flashing amber
Try just unplugging the router for 20 seconds then plug it back in.
Airpot Extreme blinks orange when connected, tried all the restarts, waiting, sequenced power downs and ups, still no luck. reckon its a switch from n to g, reckon it might be a dodgy express..anyone got...
British only say dodgy. so bingo for UK?
reckon is only said by us confederates, rebels.lol well the Arris (SB5101U) moldem is first , its LED happy./
SOUNDS LIKE IT IS BAD DO ME, IF MODEM WORKS
AND ROUTER FAILS THEN ROUTERS IS BAD.
But any router made can be not configured at all.
as in hard reset and fails. so reDO alo that. in the Airport router
AirPort extreme
Apple AirPort Extreme 802.11ac User Manual lets read some pages router
wan jack wired to wan jack on modem, check
the AP status LED light
off means no power.
sold amber means AP is process of starting up;.
SOLD GREEN LED: is good
Flashing Amber (orange/) means.
Your AirPort Extreme can't establish a connection to the network or the Internet,
or is encountering a problem. Use AirPort Utility to get information about what
might cause the status light to flash amber. See "If Your AirPort Extreme Status
Light Flashes Amber" on page 18.
the error above amber blink means the AP can not connect to the ARRIS MODEM. so reset it first. reset it by only unpluging AC power from wall for 5min and put back and wait 15min or until modem shows fully connected, to ISP./
the router is last not first. ISP not down today.
if the modem keeps failing call the ISP..
one can wire connect a PC directly tot the modem and test that way
but I will show a page on that now.
https://red-dot-geek.com/connect-pc-modem-ethernet-cable/
now you learned how to test the modem first and then router.
wired
once wired works both modem and router
we play WIFI H3LL all day long, ask. can do but endless causes to fail, in truth.
3helpful
Wireless amber light flashing problem
If the wireles light is flashing Amber .. Some one outside your house is trying to access the Wireless network . If it is always flashing amber.. try with a Firmware update available in belkin.com/au/support.
Thank You
3helpful
2answers
Flashing amber modem light on belking n wireless router
Actually there is no problem with the Modem
First Get the following Information from your ISP
1 ) The Connection Type
2 ) If it is PPPoE then Get the user name and Password
Step 1 : Connect Modem - Router - Computer (Wired)
Step 2 : Open RSP By typing 192.168.2.1 on the Address Bar of the internet explorer
Step 3 : On the Left Side Under Internet WAN Click
Connection type
Step 4 : Leave the Password Blank and click Submit
Step 5 : Select the connection type as given by the ISP
Step 6 : Click Next
Step 7 : Type Username And Password for PPPoE ,Click Apply Changes
Step 8 : There is no need to type Any Host Name for dynamic Click Apply Changes
Step 9 : If it is A Cable connection then
Step 10 : On the left side Under Internet WAN Click MAC Address
Step 11 : Click Clone
Step 12 : Click Apply Changes
Step 13 : Restart the Router
Step 14 : Check the Internet Status
Flashing PC/Activity light
Yes. I've put a piece of tape over it, so that the blinking is less annoying.
Hi - My 2wire 1701 gateway has steady green power light and steady local network light but the broadband link light is steady amber. My computer is receiving the WiFi signal but I cannot get any internet...
The broadband link light tells you the status of the connection between the modem and the broadband servers in your area. Green means everything is A-Ok while amber means your modem is not picking up a broadband signal.
Try turning the modem off and on and also make sure the cables are secure while you're at it. If the broadband light is still amber, the only thing you could do next is to call your internet service provider.
Actiontec GT701R modem
what you running it from(computerwise)..sounds like you may have a driver/interface issue with computer.
got backup?
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
