Sony STR-DE597 Receiver Logo
A
Anonymous Posted on Apr 22, 2014
How to get stereo out of protect mode - Sony STR-DE597 Receiver
Polk audio pa660 is in protection mode how do I reset it.
Lots of help in the links
Amp goes into protection mode - Polk Audio Forum
https://forum.polkaudio.com > discussion > amp-goes-i...
Nov 26, 2018 - As the title says , my 4 channel amp goes into protection mode when I turn my volume up to about 18-20 , causing a loss of sound .
Solution to my Protect Mode Problem - Polk Audio Forum
Feb 15, 2010
Speakers causing the Power Amplifier to go into protection ...
May 9, 2016
PA D4000.4 starts up in protect mode? - Polk Audio Forum
Aug 22, 2012
PA880 Help Needed - Protection Light - Polk Audio Forum
Apr 3, 2013
More results from forum.polkaudio.com
Protection Light ' Polk Audio PA660.4 Support - HelpOwl.com
https://www.helpowl.com > PA6604 > Troubleshooting
Jul 31, 2017 - Polk Audio PA660.4 - How do I turn off or get out of protection so I ca.
Car amplifier(Polk Audio PA660) question - Badcaps Forums
https://www.badcaps.net > forum > showthread
Dec 19, 2013 - The amp, is a Polk Audio PA660. It was entering in protection mode. I have found a pair of final transistors shorted at one of the ...
Amplifier Protection Mode Troubleshooting - Car Audio Help
http://www.caraudiohelp.com > newsletter > amp_prote...
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, ...
4helpful
Got in car this morning and radio was blinking protect
Hi.
Protect mode is a special condition that kicks in when an internal fault has been detected. In protect mode all the unit function are disabled to prevent the stereo getting more damage in consequence of the fault. The state is a forced standby condition that starts when a wrong voltage or a short is detected.
Try disconnecting the battery terminal, pulling the radio out of the dash and checking the wiring at the back of the stereo. Most of the time protect mode is triggered by a wiring contact. If possible check also speaker wiring. A contact in wiring to speakers will trigger protect.
Regards.
Ginko
2helpful
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
4helpful
3answers
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
51helpful
3answers
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
2helpful
2answers
My kenwood car stereo says protect how do i fix this
well that means you had a safety stereo in the beggining and you proly didnt put the safety code in so it went into secure mode it to prevent the device from working if stollen
62helpful
9answers
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
1helpful
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
