S2s 192.168.2.1 cannot be displayed
SOURCE: how do i access my belkin 54g settings
To access in your router, open a blank Browser page and type :
http://192.168.2.1 normally it's this ip :)
(note that A lot of routers setup pages are accessed through [192.168.1.1]).
username : Admin and at password leave it blank otherwise Type : admin
SOURCE: change my settings from wep to wpa
when you change the wireless security on the router , it is recommended tht you will change the wireless network name also ( SSID ). Because when you try to connect to the wireless network on the computer, your computer will try to connect to the same old network name with the old wireless security settings. To avoid this you can change the wireless network name. WPA is supported by windows XP SP2 and above operating system.
If the operating system on your computer WINDOWS XP SP1 and if you are trying to connect using the windows utility then you would not be able to connect to the network .
Click Here for more information about the routers and networking
SOURCE: belkin 54g wireless router
To reset your router to default settings, hold down the reset button for 10 seconds and realese it. Then unplug the power cord and plug it back in. This should work with most routers.
SOURCE: I need to secure my
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
