I cant connect my remote to my televison
SOURCE: remote codes for "ph301s" universal philips remote
www.remotecodelist.com .............................T.
SOURCE: programing philip universal remote to my tv
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
I lost my instructions to program my tv with the remote can you help me
SOURCE: Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
