How do I perform a factory reset of my Kyocera FS-3900DN printer?
SOURCE: Web password
You probably have a network card called a IB-30 installed. You will need to reset this card by changing the jumper from is original position to the next one. This will restore the original factory settings, there are only one jumper on the card. If you still have the CD your IB-30 came with it will explain to you under troubleshooting how to restore the factory defaults.
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: Factory Defaults for Kyocera FS-1300D
Turn off the Dell printer (assuming you want to keep that IP address as is). From the computer/server the printers are networked to, go to Printers and Faxes and locate the printer. Right-click on the printer > Properties > and there should be a tab where you can change the IP address within...sorry I can't recall the exact steps from here as I don't have access to do so from my machine. Once you change the IP, reboot printer and your conflict should be resolved.
If all else failes, you'll need to consult the NIC card manual for further diorection.
SOURCE: HELLO!!! How do I
Your printer comes with a software CD. Run the CD there's an option to reset the printer.
SOURCE: Need to reset password in Kyocera Command Center f...
The only way to reset the password, is to use the Paramter "U 24". Thus the harddisk will be formatted!
