1986 Honda GL 1200 Aspencade Gold Wing Logo
Posted on Jun 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
87 Aspencade 1200 backfires between shifts and backfires deceleration and acceleration. Have had carbs cleaned and replacement kits installed. new spark plugs. synchronization of carbs also. Checked compression and timing. New fuel filters and checked fuel pump.
Anonymous
Level 2:
  • Expert 311 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Answers
311
Questions
0
Helped
131731
Points
617
Check for leaks around the exhaust headers,mine did what yours is doing,i replaced the copper exhaust seals in the head(exhaust ports),air is getting into your exhaust system and it mixes with the unburnt fuel and ignites causing the backfire,i replaced copper seals(about $2nz each) and problem went away
1986 aspencade 11,500 miles sometimes when starting engine backfires and will not start later will start and run fine.
I suspect the carburetor needs tuned to correct the air-fuel mixture in the mid-range.It's possible that the carb
was not thoroughly cleaned and/or the fuel system upstream of the carb was not cleaned and has re-contaminated
the clean carb.
7helpful
1984 GL1200 Goldwing... 80k mi. ....bike will not run without choke on 1/4 to 1/2 open... when given throttle, the engine backfires and blows black soot out of exhaust... new spark plugs with gap set at...
This sounds like a fuel flow problem. I suggest removing and rebuilding and cleaning the entire system, meaning Carbs, filters and strainers in the tank. Old fuel turns to gel, and floats absorb fuel, sometimes, so inspedt everything. When finished set carbs with carb sticks, both at idle and at 2000 RPM, using hand throttle.
9helpful
My 1999 Honda shadow backfires on deceleration after steady throttle what could cause this? I have tuned it and cleaned the carb but it still does it.
The most common reason for backfiring is lack of back pressure from changing the exhaust. To compensate for the flat spot you get you put in a jet kit. This leaves the possibility of more unburned gas getting into the exhaust. Honda uses Kei Hin carbs with a fuel shut off diaphragm to help limit this condition (backfiring) by turning off the fuel to the carbs during deceleration. Even stock exhaust can pop or backfire. Typically it is caused by air getting into the exhaust either past the copper o-ring gaskets in the head or leaking muffler connections from the head pipes to the mufflers. Try replacing all the exhaust gaskets and you should minimize this condition.
1helpful
Backfires on deceleration and also is getting black above shift side carb.
A lot of backfiring on deceleration is related to reused or leaking exhaust gaskets in the head . The gaskets are leaking air into the exhaust. If you are experiencing carbon on the intake side , I would recommend replacing the intake o-rings and gaskets, spark plugs, and spark plug caps. These can all be related to backfiring through the carburetors.
3helpful
Backfires on down shifts and when reving up. Mainly when the rpms are going down
Your idle mixture is too lean. You can adjust this by locating the mixture screw on the carb(carbs) and turning it counter-clockwise an 1/8th turn at a time. This will not affect running above 1/4 throttle, but will richen your idle circuit and the lean popping on deceleration. If you have misses above 1/4 throttle when accelerating, tou likely have trash in your jets and the carb will need to be removed and thoroughly cleaned.
*Help me out. Rate me!
2answers
HOW HARD IS IT TO REBUILD THE CARBORATORS ON A 1984 HONDA 1200 ASPENCADE
EASY!!!! sit at your kitchet table with some towels laid out. BUY a REBUILD KIT. Have fun : ) Easy
1helpful
1984 Aspencade backfires in midrange RPMs
1. Check timing belts and ignition timing.
2. Service carburetors
1helpful
2answers
Me transmission is stuck in second gear in my 1987 honda goldwing
You have a bent shift fork. The repair is major surgery by the dealer. Sorry for the bad news.
3answers
Backfiring
Sounds like you've got a carb with a clogged jet. My guess is that the surging was a moment where the carb was actually operating well enough for the bike to run properly on that cylinder. Could also be a spark problem but you should be able to determine if this is the case rather quickly. I'd probably go ahead and replace the plugs if you haven't already...that could help...but my guess is still going to be carbs.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
