Tomtom ONE XL GPS Logo
A
Andrey SAlnikov Posted on Apr 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How I can instal another languaqe - Tomtom ONE XL GPS
compusat
Level 2:
Sergeant:
Champion:
  • Tomtom Expert 373 Answers
  • Posted on Apr 24, 2014
compusat
Tomtom Expert
Level 2:
Sergeant:
Champion:
Answers
373
Questions
0
Helped
44889
Points
507
Tomtom home, click add voices, etc
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
6helpful
5answers
Install A4 tech PK635 M web cam without cd installer
help me solve my problem give me installer
May 19, 2008 • A4tech PK5
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
